jjcomanche44
jjcomanche44's Achievements
  1. Last not someone broke into my truck and stole my radio. I believe they also tried drive the truck because it wasn't where I parked it last night. I went to start the truck this morning and it will not turnover. When I turn the key in the ignition it just makes a high pitched screeching sound. Anyone have any idea what the bandits could have done?
  2. I am trying to install a new ignition lock. Does anyone know how to disassemble the steering column?
  3. I'll drive it to your door if you have time to look at. Just let me know when is a good time for you.
  4. BLHTAZ are you in Orlando? I live in Gainesville do you think we might be able to get together sometime. I would like someone to take a look at this k comanche before I get too much money into it.
  5. I recently purchased a 1989 5-speed Comanche. There are two things that concern me. The neutral idle speed stays around 1500 rpms. Is this normal or does something need to be adjusted. Secondly, once in a while after I have applied the break when the comanche is in 3rd gear I can shift out of 3rd but not into any other gear. But if I turn the car off and back on everything works fine. (This has only happened when I was coming to a stop at a light) Am I going to need a new transmission?
