88chief
88chief's Achievements
  1. new member here aloha from oahu-- got an 88 comanche chief 150k mi. will turn over but has trouble at idle. Had always revved really high then i'd turn off and back to normal. discovered a fuel leak at an injector about the same time it began running really rough! replaced all o rings fuel pressure reg,and inline fuel filter. leak solved but still running bad. I then replaced cap rotor, plugs, egr, o2 sensor and still nothing! map sensor was within spec., also checked entry of cat converter didn't see any blockage someone out there know whats going on? no obvious vacum leaks, throtle pos sensor and mass air flow sensor seem fine please someone help!! :bowdown:
