creepin'
Everything posted by creepin'
  1. Ok I cycled the key on and off and did not get any codes from the flashing check engine light on the information center. Will a scanner show more codes than that will?
  2. How to you clean the injectors? i don’t it would believe the tps is out of adjustment the brand new one is in there just the same and the problem is still the same.
  3. I don’t have the check engine light coming on will it still show a fault code?
  4. Help I have a 92 Comanche big ton with a 4.0 6 cylinder. I have been chasing a problem with it idling rough, it started last year with it starting hard and then a rough idle and it would just randomly shut off sitting at a light. New parts- fuel pump last year, map sensor, tps, iac, fuel filter, cps, o2 sensor. tested fuel pressure 32psi at idle and jumps to 40psi when the vacuums line is removed from the pressure regulator. PLEASE HELP ANY IDEAS
  5. Anyone know of a skid plate for up for that would fit a 92 comanche?
  6. Is it possible to remove the engine without taking the transmission and transfer case out?
  7. I have a 92 comanche 4.0 HO the motor runs good and only has 90k miles. The motor runs good but need some work needs a head gasket bad and has been getting progressively worst with raping and ticking noises and it sounds like a diesel when it's warmed up and idling. I'm looking for some opinions on what I can do without removing the engine to freshen it up some.
  8. I have a 92 comanche and I'm trying to splice in a 4 wire plug for a trailer does anyone have any idea as to what color wires going back are for what I have a blue w red tracer, light green, tan, black, and brown w green tracer please help?
  9. anyone ever swap a 4bt cummins or 6bt cummins into a comanche? How hard is it when it comes to matching up the transmission? wiring? I've seen newer wranglers with 4bt's but never a comanche
  10. creepin'
    Shift Cable
    Not really I already got a new column and rebuilt it, I was able to rig up the cable and bracket I have it just goes into gear hard
  11. creepin'
    Shift Cable
    Looking for automatic shift cable from the column to the trans as well as the brackett is hooks into on the side of the bell housing aw4 trans
  12. creepin'
    Reciever Hitch
    Wanted 2inch reciever hitch for a 92 anyone out there have one
  13. maine zip-04043 its a bolt on for a comanche
  14. creepin'
    reciever hitch
    Wanted- 2inch reciever for a 92
