fiatspider
    Lexington, NC
  • Interests
    Classic Cars
fiatspider's Achievements
  1. I've found a low mileage 01 XJ engine, problem is it does not come with the wiring harness and I'm going to have a hard time finding a new enough wiring harness to work with that fuel injection system and the distributorless ignition. Can I just pull a harness, ecu, flywheel, and distributor off of an OBD1 or OBDII XJ and use that on the 01 engine along with either my current manual or maybe I'll pull a lower mileage AX-15 when i get the harness and everything else. Any recommendations on whether I go OBD1 or OBDII for the ecu and harness? thanks, -Scott Flanagan
