lighting q
Run the power wire from the speaker lights to the positive side of the switch then run the ground wire to the switch. If the switch doesn't have a ground then use a bolt on the body to attach the ground wire to. If you don't know which side of the switch is positive you'll need a multimeter.
Chris
