J8S engine wanted
Rob57
An AMC-Renault engine is needed... the Garrett T02 turbo and Bosch VE fuel pump are not required.  These engines were fitted to various JEEP models between 1984 and 1987.. with the Cherokee 2.1L TD the most common, although the Wagoneer and Comanche also fitted it. We are talking USA or Canada and I will need a contact number.  Thx...  Rob
Most engine parts, other than catastrophic failures are available online for these engines.  In this particular case, the block was broken.  If you need assistance in locating such parts, let me know.  Spokane Diesel Pump repair is where most Renault and Peugeot owners are sending their Garret turbo and Bosch VE pumps for rebuilding.  It's never cheap.
2100481751_JEEP1984-to-1986-parts-catalog-1.pdf
