chuckliddell101 Posted March 20, 2006 Share Posted March 20, 2006 Hey everybody... i got some stupid questions. 1) How do I drain the power stearing fluid so i can remove it? 2) How do i remove the second bold from the AC compressor that is blocked by the fan? Thx in advance Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted March 20, 2006 Share Posted March 20, 2006 Personally, I would not worry about removing the fluid untill it is out of the vehicle. You could pinch off the lopressure side of the pump and remove. If you HAD to drain, I would get one of those grease gun looking suction guns and suck the fluid out. As for the AC bolt, the fans/ fans shrouds are easily removable. This should gain you enough room to bo what you need to. Good Luck, CW Link to comment Share on other sites More sharing options...
