No taillight, dashlight or platelight
Hi all
Had a loose steering column that I tightened yesterday. Managed to get it all apart, tightened and put it all back togheter again. Everything worked fine. BUT it seems I now got no dashlight, taillights and platelights. Brakelights, backup and headligths, both low and high works fine. Checked fuses, and connectors under dash I might have displaced.
I'm thinking the headlightswitch, but shouldnt all lights stop working then?
Mathias
Skickat från min iPhone med Tapatalk
Usually, on every older car or truck I've ever had, if the dash lights are out, I go check the tails.  If both dash and tails are out it's the fuse.  I thought it was a GM thing, but I guess most car makers incorporate the two circuits so you'll know you have a problem with the running lights.
