bleeding a 1992 comanche clutch
There should be a bleeder valve (just like on the brake system) coming out of the bell housing. I know for the BA10-5 its on the upper portion of the driver's side bellhousing. Since yours is an AX-15 it could be difference, but should be in the neighborhood at least.
Procedure is just like bleeding brakes: Open the valve, step on the clutch pedal, close the valve, release the pedal, repeat. Make sure to add fluid to the master cylinder and never let it run dry. Also helps to have two people.
thanks buckwheat you where right I looked again and found the bleeder valve on the passenger side bellhousing
I was only looking on the side where the hose goes into the bellhousing from the slave sylinder
thanks again
1986 comanche 2.8  auto
1992comanche 4banger 5speed coffee grinder
