dkroll Posted May 9, 2015 Share Posted May 9, 2015 I have swapped out my bell housing for a "later model" external clutch set up, I have two flywheels sitting here with many questions; 1). The bell housing was from a 99 wrangler, I believe. 2). I have an old flywheel and pressure plate from "somewhere", not sure it was for a different type of tranny or what.???? 3). I have the flywheel which was from the '99 (I believe, but not 100% sure). Both flywheels look identical for the starter teeth (gears), but both flywheels have totally different "teeth" for what I believe are for the crankshaft position sensor. A). One (the newer one), seems solid with 3 sections with indent "teeth" with 4 grooves in it. B). The other has many teeth in groups of three with 20 teeth and a gap between (if that makes sense). (old one). Question one; With this truck being an '88, I feel that the crankshaft position "teeth" need to be compatible with it, so I ask;... Is "B" the right flywheel to use? I that configuration correct? I wonder how the system worked back then and if B). will work nice with the pressure plate and everything (clearance-wise and all ).? Question two; Are there any good videos or sites out there for this particular situation? I know this has been done many times, but I either need some reference or chat with someone who has done this. Question three; When did they change this flywheel configuration and why/what is the difference? I just don't want to put this together wrong and find out I must re-do a mistake. HELP!!! Link to comment Share on other sites More sharing options...
