1987 jeep Comanche - $8000 (Huntington station, Long Island, NY)
http://longisland.craigslist.org/cto/4727971962.html
1987 jeep Comanche.let me start by saying I don't need to sell it! This is more or less a feeler post. If I get offer the right number of sell it.
87 Comanche body
-fully plated (engine bay,front rails face and bottom, mid plates that tie in to rockers)
1/4" rockers made from 2x12 tube shaved cab mounts (flat from rocker to rail)
Partially Eco caged all 1 3/4 Dom
Engine is a 4.0 tranny is a ax15 (5speed) and wire harness is out of a 96 Xj with 125k on it
Transfer case is out of a 2004ish rubicon (4to1 low range) tom woods driveshaft.
Axles -front is a waggy 44 with 5lug outers -ten factory alloy shafts 4.88 gears and a full spool. Tnt truss also has PSC hydro assist .
Rear is a ford 9in custom back braced and plated with 4.88 gears and a full spoil 31 spline with Yukon shafts.
Front suspension is 3.5 RE coils with rock krawler long arm.
Rear is spring over stock leafs but I frenched the front mount 3" in to frame to get a 3" lift instead of 6"
Shocks are fox 2.0 resi custom valved front and rear.
35" bFG KM2's lil less then half tread
Interior has 2006 WRX seats with custom brackets. Dash is out of 96 cherokee. New carpet
Asking 8000 obo. Don't offend me and lowball me I will simply not answer you.
Serious inquiries only . I've spend a lot of money and time building this truck don't want to sell it but testing the waters.
