T-Case Input Shaft
The NV4500 I am using in my cummins conversion is from a late model GM. 32 spline count output shaft. I want to use an NP242 on this project. So I should be able to find an NP 200 series t-case from a GM and swap out the input shaft then bolt it up to the NV4500 and all is good?
