Replaced Exhaust/intake Gasket. Still Leaking
So i just replaced my manifold gasket and also used some hi-temp copper spray on the gasket to help a little. I took everything off and sanded the two mating surfaces so they are flat.
Now two out of the three studs were loose when i uninstalled the manifolds so i put red loctite on them, screwed them back in and let them cure. I then inserted the gasket in, put loctite on the bolts and torqued in a sequential order. But i still have a leak. There is a distinct ticking sound when load is put on the engine.
So i guess my question is... Can a exhaust leak cause such a vaccum leak or would it be just the intake manifold. Because i am still have a rough idle. But its just ridiculas that i just replaced the gasket. Any input?
I did not actually take off the exhaust manifold so I wouldnt have to deal with the rusty bolts and donut gasket at the end of the manifold. So I checked for cracks where I could. There was not any old gasket left on the manifold when I installed it.
Would an exhaust leak cause idling issues though? A vaccum leak....
