Need Help Fast !
i had to replace my fuel pump in my 88 2.5 i also moved to a external tank in the bed instead of the one under it because it was rusting out anyway when i finished i had the fuel pump wired to a toggle switch just off my battery my real problem is that when i started it the truck ran fine  but for some reason the volt gauge only read 12 volts so i tried with my multi meter and sure enough 12 volts so i replaced my alternator with a brand new one and i am still having the same problem
