huricane4 Posted April 29, 2013 Share Posted April 29, 2013 What 1-1/8 or bigger MC would be a direct fit (besides brake lines)? I know that Mercury Merquise will fit butt what year or part NR? Link to comment Share on other sites More sharing options...
Garvin Posted April 29, 2013 Share Posted April 29, 2013 '78ish Grand Marquis with 4 wheel disc and hydroboost is the direct bolt in upgrade. You can pick up two of the premade shot lines and just bend them and they will have the correct ends to convert from the Marquis master to the Jeep prop valve. Link to comment Share on other sites More sharing options...
huricane4 Posted April 30, 2013 Author Share Posted April 30, 2013 Thanks so you think this will work? http://www.ebay.com/itm/Centric-Parts-Brake-Master-Cylinder-130-61023-/111047556859?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1978|Make%3AMercury|Model%3AGrand+Marquis&hash=item19daf33efb&vxp=mtr http://www.amazon.com/gp/product/compatibility-chart/B000C01Z70?ie=UTF8&i=0 Seems that the hydroboost is rear drum? Link to comment Share on other sites More sharing options...
Garvin Posted April 30, 2013 Share Posted April 30, 2013 http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_master-cylinder--remanufactured-cardone_5350867-p?searchTerm=brake+master That's the one I'm running. They make a front disc/rear drum, front disc/rear disc and hydroboost front disc/rear disc from what I've seen. You want the last one. They supplied my rear disc/rear disc on my Cherokee nicely (3/4 ton Chevy rear) as well as the rear disc/rear drum stock setup on my '86. They also supply the rear disc/rear drum one ton setup I currently have on my Comanche without an issue. This was all with a single diaphragm booster. Link to comment Share on other sites More sharing options...
