jackel18 Posted March 26, 2007 Share Posted March 26, 2007 i just lost my brakes. don't know what happened. the rear drums and lines were all replaced last summer and it has been working fine. i was on my way home from work today and they did work till i was about a mile from home and then the i pushed the pedel to the floor and i had nothing. its raining right now so i can't see any leaks, but where should i start looking? Link to comment Share on other sites More sharing options...
87manche Posted March 26, 2007 Share Posted March 26, 2007 check the master for fluid. Even if you had a leak, the front and rear circuits don't share a resovoir, so one or the other should have worked. I lsot the rears completely one day, the pedal was odd, and I only had front brakes. anyway, enough of that. What happens when you press the pedal, does it slowly sink to the floor? Try stabbing at it hard and fast, if that works then I'd suggest you have a master cylinder problem. If the pedal is hard as a rock then the booster is likely died, or the vacuum hose has fallen off. Of course, you should inspect all of the hard and soft lines, and don't forget to take off the rear drums, in case you popped a wheel cylinder. Link to comment Share on other sites More sharing options...
