Random Xj/mj, 4.0, And Some Yj Parts...
bumpy
All parts are located in Troy, Michigan which is about 10 minutes from Detroit. you can pickup whatever or i can/will ship on your dime... i have friends who work at the UPS store so shipping for most things shouldnt be too bad...
I am trying to move out of state within the next 2 weeks, so i will not turn down any reasonable offer as i need to get down to a minimal amount of parts and one car (i have 3) to take up less space in my parents garage/yard... thanks for any help yall may be!!! may also be able to take whatever on the road if your able to be somewhere along the i80 all the way from Detroit to Reno...
XJ soundbar, was for my '92, needs a good cleaning/possible re-uhpolster.. couldnt make it work in my MJ... $35
cluster from a '91.. 242k on it $20
chrome power mirrors from a '92, cut wiring harness $20
power steering pumps...
1 is good $40
not sure on the other whole one $20
the one for a core $5
power steering reservoir $10
Pre 96 spray tinted taillights $40
broken d35 lunchbox locker, one piece broke, maybe you have another with a broken part in it? $?? $25?
4.0 valve cover $25
4.0 starters, i have 3 still.. $40each
4.0 ac compressor for 97+, worked when pulled!$80
4.0 distributor cap - free with something else
4.0 thermostat housing - $10
4.0 alternator 90 amp $50
4.0 intake manifold with fuel rail and injectors $75
4.0 throttle body $40
Jeep 4.0 flywheel from a '99 XJ - $75
4.0 coil $25
np231 tailcone, yj bumpstops, TB filter boot, d35? yoke - all free with purchase of something...
4.0 fan - $30
flowmaster? 3" muffler, offset/center 3" in/out $60--now $45
YJ heater stuff... all ducts, heater core, blower motor $20??
YJ gas pedal, fuel neck holder thing, rear tire bumpstop, door latches, shifter cover $10 for all or free if you buy something else?
4.0 motor mount, forgot what side? assuming the driverside.. $20?
97-01 XJ seats and console -- $150 for all obo... was gonna swap these into my MJ, but theres wayyyyyyyy too much rust to convert it to buckets =(
I'm pretty sure i have a MAP and CPS from a 92-99 as well.. also have the 4.0 ac brackets, fan brackets and idler pulleys...
Archived
