d35 question
yes, it was called Track Lok by jeep, if you've got one it will have a note that you should use a limited slip additive, either on the tag on the diff or in the glovebox.
If you've got neither and suspect you've got one, pop the cover and look for the clutch packs where the spider gears normally reside.
