abetterthanyours Posted January 6, 2013 Share Posted January 6, 2013 hi i am new to the fourm and also new to owning a 88 jeep comanche. i went to try and pass emissions and no luck. first time i went i got pass on hc fail co 26.45 actual, 25 limit. and pass on nox. second time after adding special additive to the fuel (which has always help my vehicles pass with flying colors) i failed again this time 25.51co. i really need to regester this truck and every thing that i look at seems to be fine. i checked: map iat or mat as jeep refers to it cts spark fuel injectors cat o2 compression changed oil checked valve springs when i preformed a vacuum test i found that it jwas bouncing between 17-19 at idle which is an indication of valve guide wear, no other signs are evident; i.e. smoke or fouled plugs. it also has an intermittent miss that i can't pin to a cylinder. truck has 150+ miles on it. i am really at a loss. any ideas would be great. Link to comment Share on other sites More sharing options...
Harley Posted January 6, 2013 Share Posted January 6, 2013 Check your state laws. Here in NV anything over 20 yrs old is considered a classic car and you can apply for an exemption from the smog testing. Link to comment Share on other sites More sharing options...
abetterthanyours Posted January 6, 2013 Author Share Posted January 6, 2013 i think that is for vehicles that are driven limited miles per year. i tried to find the exact number but i couldn't. Link to comment Share on other sites More sharing options...
Harley Posted January 6, 2013 Share Posted January 6, 2013 Each state has their own regulations as far as mileage limits, time of year, etc. Where are you from? Link to comment Share on other sites More sharing options...
abetterthanyours Posted January 7, 2013 Author Share Posted January 7, 2013 arizona Link to comment Share on other sites More sharing options...
desertmike Posted January 18, 2013 Share Posted January 18, 2013 I had problems years ago. Changing the CAT solved them all. Link to comment Share on other sites More sharing options...
