jahiatt Posted December 9, 2012 Share Posted December 9, 2012 Can anyone help me out on taking apart the fuse block on a 86 so I can try to seal and fix a water leak? I hate fooling with wires, is it just plug and play? Thanks Link to comment Share on other sites More sharing options...
ParadiseMJ Posted December 10, 2012 Share Posted December 10, 2012 There is a tiny 6mm bolt in the very center of the fuse block under the hood on the firewall. It is small, it's recessed, it's a btch to get at. Remove. Four large machine screws (phillips) on the inside, loosen. Pry two halves apart, carefully...inside and outside. Remove machine screws, pull the two halves apart...would be easier with a helper to pull(inside) when you pull (outside). Link to comment Share on other sites More sharing options...
