'89 Comanche 4.88 Gears/lockers/dana 44 $2500 -Wi
wolfgraj
I have a '89 Comanche for sale near Appleton WI. I have been working on the truck for the past couple years and really hate to see it go. Especially since I have JUST finished it.
Specs:
'89 Jeep Comanche Pioneer
Drive train mileage 70,000
Body mileage -~130,000
Drivetrain:
Renix inline 6
AW4 Automatic Transmission
NP231
Dana 30 Front Axle (non-Vacuum disconnect, out of '95 Cherokee with x297 u-joints)
Dana 44 Rear Axle
4.88 gears -NEW
Aussie Auto Locker In Front axle -NEW
Aussie Auto Locker in Rear axle -NEW
33" x 12" Tires (with 600 miles on them) on 15" steel rims
Spark Plugs -NEW
Spark Plug Wires -NEW
Distributor Cap -NEW
Distributor Rotor -NEW
Battery -(Cheap model but NEW)
Converted cooling system
Suspension/Steering:
Front BDS 3.5" Lift coils -NEW
JKS quick disconnect sway bar links -NEW
Bilstein 5100 shocks Front/Rear -NEW
Coil isolators -NEW
Adjustable Sway bar with drop bracket -NEW
Hell Creek Rear Leaf Packs -NEW
Rough Country Long arm kit -NEW
Tie Rods (Moog) -NEW
Tie Rod Ends (Moog) -NEW
Brakes:
Front Calipers (not chinese) -NEW
Front Pads (not chinese) -NEW
Front Rotors (not chinese) -NEW
WJ Master Cylinder
WJ Brake Booster
Adjustable Proportioning Valve for rear drums -NEW
All new brake lines
Interior:
Bucket Seats
Center Console
Carpet removed
Bedlined
Full gauge cluster swap
Exterior:
Single Stage Black (4 heavy coats) -NEW
Notes:
The trucks exterior is HIGHLY custom. I have trimmed the wheel wells front/rear to accommodate at least 35" tires. I did extensive body-work to give a finished look and, more importantly, strength. The bottom 4" or so of the entire truck have been trimmed to give more clearance. The bottom of the doors have thick angle iron welded to them. The weak sheet metal rockers have been replaced with 2" x 5" box steel. The gas tank has been mounted on separate rails allowing you to remove the bed without dropping the gas tank.
Gripes:
There are a few items that I didn't have time to address:
1.) The hydraulic ratio of the WJ master cylinder with the stock Cherokee calipers gives a soft feeling to the brake pedal. I can assure you that the brakes are safe, bleed properly, and will stock the truck as fast as friction will let it.
2.) There is no front bumper. I was planning a custom bumper. The stocks mounts will allow you to bolt on a stock bumper if you choose. I will also include some steel to fabricate your own bumper.
3.) The rear bumper is not finished. I have a basic bumper made out of steel with recovery points and receiver but it is not painted and aesthetically finished. I will include some steel to finish.
4.) New transmission cooler lines are needed. I currently have the cooler bypassed. The truck has been driven ~10 miles like this. My intent was to purchase an aftermarket cooler.
5.) The speedometer cable needs to be replaced.
6.) To complete the gauge swap the temperature switch in the back of the block needs to be changed to a temperature sensor.
7.) The stock radio doesn't work.
8.) The tailgate I have for the truck has not been painted.
9.) The gas filler door has not been painted.
I have to sell the truck tomorrow else it goes into storage for a long time. $2500 is a VERY aggressive price and I expect it to be gone.
Contact me at:
wolfgraj@msoe.edu
I'm interested in this truck maybe you can call me at (201) 280-9420, Rich I would like to see more pictures and spek to you Wi is a far trip. I will fly out and drive it home if that is doable. if you are going to sell it I will buy it.
Sold
Archived
