boardmanMJ Posted November 5, 2012 Share Posted November 5, 2012 well long story short i might be getting an 88 longbed sometime soon. the owner now converted the front end to the 97+ cherokee but he said when you have the right turn signal going with your foot on the break the rear turn signal won't flash. its only on the right side. is this an easy fix? Josh Link to comment Share on other sites More sharing options...
Guest Posted November 5, 2012 Share Posted November 5, 2012 Sounds like he may have buggered the wiring for the front right turn signal. My first guess would be to check the connections and wiring up there; and if the wiring isn't messed up, check the connection on the back taillight. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted November 6, 2012 Share Posted November 6, 2012 Sockets...always check the sockets. Grounds...always check the grounds (especially the one hiding behind the drivers side tail light). Trailer wiring...always check the trailer wiring. Link to comment Share on other sites More sharing options...
