luvmyglock Posted July 8, 2012 Share Posted July 8, 2012 Title says it all. This is the underside of a 1989 Comanche with the 4.0L I6 and a BA tranny. There is a sensor that is not plugged in to anything, and a wire with two plugs that is coincidentally not plugged in to anything as well. What is it and which wire goes to which terminal? Thanks! Image Not Found Image Not Found Link to comment Share on other sites More sharing options...
Harley Posted July 8, 2012 Share Posted July 8, 2012 Mine has the same, I may be wrong but I believe its for the reverse lights. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted July 9, 2012 Share Posted July 9, 2012 Well from the pics all I can see is that the backup lights are not plugged in on the tranny. The 2 "studs" sticking out of the the trans are the back up light terminals. The plug for the terminals is a round thing with two holes (for the studs). It plugs in upstairs to a 4 prong female plug. You may not even have the plug as I don't see it there. Are your back up lights working? Link to comment Share on other sites More sharing options...
