Jeep4life Posted April 11, 2012 Share Posted April 11, 2012 I've been having some minor dash light problems. When I turn the lights one the dash lights go out as long as the clock and radio lights go out. What may be the problem? Is it as simple as a fuse? Thanks for the help :jump: Link to comment Share on other sites More sharing options...
deziped Posted April 11, 2012 Share Posted April 11, 2012 A bad 5 Amp INST LAMP fuse at upper right side of fuse box (depending on vehicle) can cause this problem you have described. At initial startup radio & clock light are controlled by ignition switch, however, when you pull the light switch thier control is assumed by that switch. So bad fuse, no dash lights. Link to comment Share on other sites More sharing options...
Jeep4life Posted April 11, 2012 Author Share Posted April 11, 2012 Thanks for the help. I'll have to check it and see what I can do :cheers: Link to comment Share on other sites More sharing options...
deziped Posted April 12, 2012 Share Posted April 12, 2012 Are you aware that you can turn the dash lights on (bright) & off (DIM) by turning the light switch knob CW or CCW. Try that mayb their just turned so low they appear to be ofF. Link to comment Share on other sites More sharing options...
Jeep4life Posted April 12, 2012 Author Share Posted April 12, 2012 Yea it was just a fuse problem. Lol thanks for the thought tho Link to comment Share on other sites More sharing options...
