jeepcoma Posted March 13, 2012 Share Posted March 13, 2012 Seems like every time I fix one thing leaking, there are now two leaks to fix. Ugh, I just want this Jeep to work for once! Almost there, "just a few more things" to fix. First up is the stock D30 pinion seal. Looks like the seal is the same as the D44. Cool! While I'm at the seal, I might as well replace the yoke in case it's pitted or damaged. I can't remember the u-joint series I need though or the spline count of the D30 (ok, I'll be honest, I didn't forget, I never really knew). Yoke options: "fine spline", 1310 series, 3.219" snap ring span, 1.062" cap diameter (2-4-8091-1X) 26-spline, 1310 series, 3.219" snap ring span, 1.062" cap diameter (2-4-8091X) 26-spline, 1330 series, 3.625" snap ring span, 1.062" cap diameter (2-4-3581-1X) 26-spline, 1330 series, 3.625" snap ring span, 1.125" cap diameter (2-4-6111X) I'm pretty sure I need the 26-spline 1310 but some confirmation would be great before I order (though I suppose I could call them :nuts: ). Reading through this all after typing and triple-checking RRP's site, I think the first two are identical with the exception of strap vs u-bolt (since they are also listed as YY D44-1310-26S and YY D44-1310-26U), which makes me feel better. 8091X also takes u-bolts instead of the strap, so I'd need 2-94-28X and YMS5778 for the seal. Any problems or recommendations with the above selection? I already used Randy's Ring and Pinion to do the same repair for my D44 (and "upgraded" to u-bolts) so I figure I will order from them again. Second problem is the AX-15 is leaking out the rear seal (probably nicked it when I pulled the d-shaft to fix the pinion seal!). I'm not sure what this is technically called, but I found National part 223253 at listed for AX-15 4x4 (there is a different part listed for AX-15 2x4). Any better brand seals to go with? Is replacement as straightforward as doing the axle pinion seals (pry out, pound in)? Link to comment Share on other sites More sharing options...
