kyleag89 Posted February 18, 2012 Share Posted February 18, 2012 First off its an 89 4.0 BA10 So on a cold 25-35 degree morning the MJ fires right up but will idle at about 200RPM just barley enough to keep her running. When it is colder than 25 I need to give it a little gas to keep it running. After running for about 2 mins the idle slowly gets up to where it should be(about 700-800RPM). Then when the motor is hot 190-210 it idles at 1,000RPM all the time. The IAC is 1 year old and I recently just cleaned the TB and removed the IAC and cleaned the hole where it seats. IAC still looked new, and very clean. Could I possibly have a bad IAC already or could the TPS be the issue? Thanks in response! Forgot to mention I never touched the TPS so the adjustment is the same it has always been since 2007 when the truck was purchased. Link to comment Share on other sites More sharing options...
chastings Posted February 18, 2012 Share Posted February 18, 2012 This must be contagious, there have been lots of idle problems lately, myself included! I copied the following post from cruiser54 (a member here) and it's spot on. It fixed my idle problem and several other issues, good luck. OP, you have the classic symptoms of a failed/failing TPS. I'm including the adjustment/test procedure for the TPS along with the something else that needs to be addressed on all 1987s and 1988s. You also have a connector in your harness which carries a bunch of signals between the sensors and the ECU. Resistance in that connector can give the ECU false info. The connector needs to be cleaned out. Renix Jeep C101 Connector Refreshing The C101 connector on 1987 and 1988 Renix Jeeps was a source of electrical resistance when the vehicles were new. So much so that the factory eliminated this connector in the 1989 and 1990 models. The factory recommended cleaning this connector to insure the proper voltage and ground signals between the ECU and the fuel injection sensors. We can only imagine how this connector has become a larger source of voltage loss and increased resistance over a period of almost 25 years. The C101 connector needs to be cleaned at least once in the lifetime of your vehicle. Chances are it’s never been done before. Almost every critical signal between the engine sensors, injectors, and the ECU travel the path through the C101. The C101 is located on the driver’s side firewall above and behind the brake booster. It is held together with a single bolt in it’s center. To get the connectors apart, simply remove the bolt and pull the halves apart. You will find the connector is packed with a black tar like substance which has hardened over time. Take a pocket screwdriver or the like and scrape out all the tar crap you can. Follow up by spraying out both connector halves with brake cleaner and then swabbing out the remainder of the tar. Repeat this procedure until the tar is totally removed. This may require 3 or more repetitions. Wipe out the connectors after spraying with a soft cloth. If you have a small pick or dental tool tweak the female connectors on the one side so they grab the pins on the opposite side a bit tighter. Apply a true dielectric grease, not the stuff that came with your brake pads, to the connection and bolt it back together. RENIX TPS ADJUSTMENT Before attempting to adjust your TPS be sure the throttle body has been recently cleaned. It's especially important that the edges of the throttle butterfly are free of any carbon build-up. IMPORTANT NOTE: Using the positive (red) lead of your ohmmeter, probe the B terminal of the flat 3 wire connector of the TPS . The letters are embossed on the connector itself. Touch the black lead of your meter to the negative battery post. If you see more than 1 ohm of resistance some modifications to the sensor ground harness will be necessary. The harness repair must be performed before proceeding. I can provide an instruction sheet for that if needed. MANUAL TRANSMISSION: RENIX manual transmission equipped XJs have a three-wire TPS mounted on the throttle body. This manual transmission vehicle TPS provides data input to the ECU. The manual transmission TPS has three wires in the connector and they're clearly embossed with the letters A,B, and C. Wire "A" is positive. Wire "B" is ground. Key ON, measure voltage from "A" positive to "B" ground by back-probing the connectors.. Note the voltage reading--this is your REFERENCE voltage. Key ON, back-probe the connector at wires "B" and "C". Measure the voltage. This is your OUTPUT voltage. Your OUTPUT voltage needs to be seventeen percent of your REFERENCE voltage. For example: 4.82 volts X .17=.82 volts. Adjust the TPS until you have achieved this percentage. If you can't achieve the correct output voltage replace the TPS and start over. AUTOMATIC TRANSMISSION: RENIX automatic transmission equipped XJs have a TPS with two connectors. There is a flat three- wire connector, same as the manual transmission vehicles have, and it is tested the same as the manual transmission equipped vehicles--FOR ENGINE MANAGEMENT RELATED ISSUES. However, the automatic TPS also has a square four-wire connector clearly embossed with the letters A,B,C, and D. It only uses three wires and provides information to the Transmission Control Module. Key ON, measure voltage between "A" positive and "D" ground. Note the voltage. This is your REFERENCE voltage. Back-probe the connector at wires "B" and "D". Measure the voltage. This is your OUTPUT voltage. Your OUTPUT voltage needs to be eighty-three percent of your REFERENCE voltage. For example 4.8 volts X .83=3.98 volts. Adjust the TPS until you have achieved this percentage. If you can't, replace the TPS and start over. So, if you have an automatic equipped XJ your TPS has two sides--one side feeds the ECU, and the other side feeds the TCU. If you have TRANSMISSION issues check the four-wire connector side of the TPS. If you have ENGINE issues check the three-wire connector side of the TPS. For those with a MANUAL TRANSMISSION--the TPS for the manual transmission XJs is stupid expensive. You can substitute the automatic transmission TPS which is reasonably priced. Link to comment Share on other sites More sharing options...
kyleag89 Posted February 18, 2012 Author Share Posted February 18, 2012 I am going to check my TPS but the part about cleaning the connector doesn't apply to me because my MJ is an 89. Link to comment Share on other sites More sharing options...
chastings Posted February 18, 2012 Share Posted February 18, 2012 Good call, my 87 has the connector and was ridiculously filthy, but my 89 has been great since they changed from the c101. Link to comment Share on other sites More sharing options...
