Fuse Block
You shouldn't need to pry on it at all.
Hard to see but in the engine compartment (on the engine side of the fuse block) right in the middle of the fuse block there is a small (like 6 or 7 mm) bolt. That needs to be removed, it can be a pain to get to but it's gotta come out...and then the 4 screws on the inside and it should just pull apart.
