goatroper57 Posted November 22, 2011 Share Posted November 22, 2011 hello all i have a 1986 comanche with GM 2.8 motor and iam needing the rear 4.11 ring & pinion with the dif.case (the part that the ring gear bolts to) i have 3.54s or 3.55s ratio in it now plus i need the flywheel w/bolts for the GM2.8 motor if you have one or both how much and what the shipping will be to annapolis mo. 63620 thanks all :USAflag: Link to comment Share on other sites More sharing options...
goatroper57 Posted December 5, 2011 Author Share Posted December 5, 2011 no longer need this part but i have a front axle with 4.10 ratio for sale instead i found a 3.55 axle for it but thanks all Link to comment Share on other sites More sharing options...
