cklanish88mj Posted August 3, 2009 Share Posted August 3, 2009 has anyone fixed a rusted unibody on there comanche b4 if so any pic or pointers pass side from lca mount to spring hanger bad how to fix it Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted August 3, 2009 Share Posted August 3, 2009 Check out my build thread. The link is in my signature. I fixed mine, it was badly rusted on both sides. OR go here to my photo-bucket account. Sign in cwlongshot password JEEPER. CW Link to comment Share on other sites More sharing options...
cklanish88mj Posted August 3, 2009 Author Share Posted August 3, 2009 here are pics of my uni body Image Not FoundImage Not FoundImage Not FoundImage Not FoundImage Not FoundImage Not FoundImage Not Found its all on the bottom and out side of the rail Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted August 3, 2009 Share Posted August 3, 2009 Looks just like mine did!!! Seems to be a daunting task, but mine went very well. A couple other guys here have also done this. You need some basic tools, a welder and high speed grinder as well as steel. I used 1/8". A couple pointers: Cut out and treat all bad steel. POR 15 is your friend!! Mask/respirator is advised. Use the high speed grinder with a twisted cup brush. A sawzall helps but isn't necessary. Make repairs at least 6" bigger then hole. "Fish mouth" the ends of all repair panels. Welding in flat straight repair panels actually creates a weak spot in your frame. Again, check out my build thread for lots of pics and descriptions. CW Link to comment Share on other sites More sharing options...
