Thats good info. I always did the toe-in myself, but the caster info was new. I always just eyeballed it. Which didn't work. Once I got to 6 inches, I got vibes plus death wobble. Like many people, I replaced most of the front end with little results. Didn't go away until I got the RE drop brackets. That makes sense since they pull the caster back closer to normal. I probably could have done it with longer control arms and shims, but the RE brackets also make it perform a lot better so I'm happy.
