92comanche4x4 Posted December 14, 2008 Share Posted December 14, 2008 would my slave be inside the bell housing or outside on a 88 4cyl 4spd? and what side would it be on Link to comment Share on other sites More sharing options...
92comanche4x4 Posted December 14, 2008 Author Share Posted December 14, 2008 would my slave be inside the bell housing or outside on a 88 4cyl 4spd? and what side would it be on Link to comment Share on other sites More sharing options...
ocskipper Posted December 14, 2008 Share Posted December 14, 2008 The slave is on the inside if the bell housing. There should be a bleed line that comes out though. If you are checking for a leak, usually the bottom of the bell housing will be stained or wet. Link to comment Share on other sites More sharing options...
