I was about to cut down and weld the 2wd rear driveshaft to correct length. But I thought someone had gone to the bone yard and found a possible swap from a particular car. I changed over to 4wd with 4.0, automatic, and 242 t-case. Truck is swb and all stock. If someone has some good info, I would appreciate any suggestions.
