1J7FJ66L8LL121080
89 MJ
*Q7 Cloth Low-Back Bucket Seats
-SA Charcoal
169 Zone 69-Phoenix
1AA U.S. Dealer Retail
5KR Midland Corporation
ADA Light Group
ALR
APA Monotone Paint
ARM Radio AM/FM Cassette
BA1 100 AMP ALTERNATOR
BCY 475 AMP BATTERY
BGA Power Front Disc/Rear Drum Brakes
CAC Low Back Bucket Seats
CDB Reclining Front Seats
CKA Carpets - Floor and Cargo Area
CSR Passenger Assist Handles
CUF Full Length Floor Console
DBB All Manual Transmissions
DDQ 5-Speed Manual Transmission
DHN Command-Trac Part Time 4WD System
DJH 230MM Front Axle
DMM 3.07 Rear Axle Ratio
DRJ Dana 35 Wide Rear Axle
EAA All Engines
EAF ALL FUEL INJECTED ENGINES-GAS
ERB ENGINE - 4.0L I6 MPI GAS
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GFD Rear Sliding Window
GNA Rear View Day/Night Mirror
GNB Driver Side Illuminated Sun Visor
GNC Sun Visors w/Illum Vanity Mirrors
GRZ Left Remote Mirror
GSZ Right Remote Control Mirror
GTZ Manual Remote Mirrors
HAA Air Conditioning
JAY DO NOT USE - See JP, KA classes
JCA 85 MPH Primary Speedometer
JGB Digital Clock
JHA Var Intermittent Windshield Wipers
JJA Cigar Lighter
K2B STRIPE/BADGE/MOLDING/COLOR
K3R STRIPE/BADGE/MOLDING/COLOR
KLH
LAJ Headlamps On Warning Chimes
LAP Shift Indicator Warning Lamp
LBB Courtesy Lamps
LBC Glove Box Lamp
LBD Ash Tray Lamp
LBE IP LED Ambient Light Pipe
LCJ DOME/READING LAMP B-PILLAR
LDH U/Hood, Removable/Rechargeable Lamp
LHD Headlamp Off Time Delay
LMA Halogen Headlamps
LNJ Front Fog Lamps
MB1 Black Front Bumper
MBJ Black Bumper
MCA
MDA Front License Plate Bracket
MFK Body Color Grille
MHA Black Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMK Lower Grille Surround-Painted Silver
NAF High Altitude Emissions
NBK EVAP Control System
NF2 18.5 Gallon Fuel Tank
PE4 COLORADO RED CC PRI PNT - HE4
QE4 COLORADO RED CC SEC PNT - HE4
RAA All Radio Equipped Vehicles
RAF AM/FM Cassette Radio
RCD 4 Speakers
SBA Power Rack and Pinion Steering
SCG Leather Wrapped Steering Wheel
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
SUA Tilt Steering Column
TAA All Tires
TBC Compact Spare Tire
TBM Tire Carrier Winch
TRN P225/75R15 OWL Wrangler AT Tires
WJH 15X7 Aluminum Wheels
WLZ All Aluminum Wheels
XBS Pickup Box
YAA Build To U.S. Mkt. Specifications
YEP Manuf Statement of Origin
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z5A GVW/Payload Rating
Z66 Left Front Group XV
Z85 Right Front Spring Group XIV
Build date 8/24/89
Body code JL61
VIN:1J7FJ66L8LL121080
How TF did an AZ MJ make it up there and turn into a pile?
Does this truck actually have these things? If so, I need to pull them for my blue truck, just in case.
While I have been pulling parts off of it, I have noticed it seems to be a fairly well optioned truck. It has the color matched grill and headlight bezels (looks stock, other than the repaint), body color fender flares (or it did before they were painted), full gauge cluster, bucket seats and a tilt column. Could this truck be an Eliminator? It seems pretty well optioned, even just to be a base or a Pioneer.
4 minutes ago, Pete M said:
the first number 6 in the VIN says you are correct :L:
Wild! Thank you! I have owned 3 of the major trims! Base (my blue Sportruck), my red Pioneer (Ugly Truckling), and now this Eliminator
