I bought an 87 Comanche about 3 weeks ago as an intended unique daily driver year round to keep the salt off my TJ.
It's too good, and I fell in love immediately.
I'll give a brief history of myself, as uninteresting as it may be.
I was born in 89.
I was driving my dad's 95 Dakota around the yard right after he got it.
Once I had that down, my mom taught me to drive stick in her 94 Geo Prizm.
I bought my grandma's car, a 90 Pontiac Sunbird auto, in 2004 for $500.
After that, it was, in order:
1992 Celica GTS 5 spd
1990 4Runner SR5 V6 auto (which I rolled offroad, and burned to the ground)
1988 Corolla GTS 5 spd
2006 TJ SE 2.4 6 spd
1989 MR2 NA 5 spd
2011 Mini Cooper S 6 spd (new off the lot)
2005 TJ Rubicon 6 spd (still have as my daily, replaced the Mini cause I missed the Jeep so bad)
1995 Ranger V6 5 spd
1991 Celica Alltrac 5 spd (still have)
1982 Wagoneer Limited (still have, not running, in storage)
2014 Ford SVT Raptor
1987 Jeep Comanche, 2wd, 5 speed, 2.5 liter.
And I guess you can count the 86 Comanche donor sitting beside me in the garage as I type this.
I never made a build thread anywhere for my TJ, because I never intended it to get to that point. As of writing it has $35k into it in parts alone, all labor me aside from the regear. And I'm waiting on the supercharger kit to show up.
So with that, I'm starting a thread on the MJ.
I've had it for 3 weeks and it's already taken over my garage.
Share this post
Link to post
The Jeep is an 87, 2.5, 2wd, 5 speed. According to carfax it's been in two fender benders, one in front, one in back. There is still evidence of the front impact. No evidence of the rear impact although the bumper is missing. It's got some minimal rust but it seems very much to be surface rust. I'm in Minnesota but the truck is from Georgia. PO put a 3" lift on it.
The floor on the driver side is gone. Passenger side is bad.
Interior needs some parts.
So as I said, had it about 3 weeks now. So far...
I replaced some burned out bulbs, but have an issue with the front left. Bulb is not burned out, will not light. Need to check the wiring.
Replaced rear view mirror that was gunked up under the glass.
Replaced driver side wing mirror that was sagging, and chrome. Passenger side is black. Now they match.
Fixed grinding terrible driver side window "regulator?" Lots of grease. Sheath (?) had come off and was rusty.
Replaced simple gauge cluster with full cluster, calibrated tach using laser handheld.
Replaced oil pressure and coolant temp sensors.
Bought driver side floor pan.
Ordered both front fenders.
Replaced glasspack muffler with Borla
Wired clock to actually work.
Rebuilt shift tower bushings/centering pins
Share this post
Link to post
Drove 3 hours to pick up an 86 donor MJ. 2.5 missing, but np207, ax5, and d30 present. We goin 4wd!
I have the trans and tcase out, axle is half out and will be finished tomorrow.
Snagged a few small trim parts and whatnot off an 89 at the junkyard
Share this post
Link to post
Now the following is info I couldn't find specifically, it seems to be a grey area. I saw a lot of good posts by a user name Eagle and some other old links but pictures just don't work anymore. So I'll try to use a lot of key words so this is searchable. I might type some of the following oddly, because I know how important this is to people and most don't post after they figure it out.
86 87 88 89 cluster swap conversion
First I will outline what I gathered as the general community consensus.
84 - 86 has metal connector on speedo speedometer cable.
87 - 90 has plastic connector on speedometer cable.
88 - 90 tach tachometer has an adjustable pot on the back for cylinder count
84 - 87 old style one notch per mph on speedometer tachometer in double (2) digits
Bought an "87-90" cluster off ebay. It was a gamble, had the old style gauges. My intent was to swap from no gauges and dummy lights to a full dash.
My gauge as stock in my 87 is at the bottom. Unspecified "87-90" on the top
Took the cluster out of the 89 XJ sport 4.0 5 spd 2 door at the junkyard (what a rare beast itself)
Here they are beside each other, "87-90" on top, 89 on bottom
Here they are with the surrounds replaced, they are swappable, just to answer that question. I'm keeping the old style 100%.
There's question if the 87 has an adjustable tach. Again, the one I got off ebay has what looks like an 87 and earlier style, but it does indeed have the pot on the back of the tach. Check the following photos, and I tried to tip the photos at an angle so you can see the style between the two without confusion.
Wm15pdD.jpg?1
Tg0xAhy.jpg?1
Share this post
Link to post
So I also read that the pot was only adjustable from 6 cylinder to 4 cylinder.
I was trying to adjust a 4.0 tach for a 2.5.
I tried adjusting both. All the way left counter clockwise made my tach so low it wouldn't read at idle. It definitely seems as if there would be ample adjustment for a v8 because...
All the way to the right was too high. It read 1k rpm when the engine was idling at 850 rpm on the laser tach. This may need adjusting and I will update
YVm0Ada.jpg?1
Share this post
Link to post
Just went through this with the blue cluster. It’s a finicky thing to get adjusted just right. I’ve had mine for almost a year now and I finally got the tach in the sweet spot for the 2.5L. The REM helped me a lot both times I adjusted it.  Course, i don't know how it was off the first time I adjusted it as I used the REM.
You'll get it adjusted where it needs to be.
Share this post
Link to post
Yeah I got it within ~15 at idle but when revving it seems to read waaay high. I gassed it off my street and it ran to 6k on the tach and sounded like 4kish to my untrained ears. I'll have the girlfriend hold the throttle while I adjust
Share this post
Link to post
So if anybody tells you all manual trans 2.5 MJs are 4.10s, like I was told, they're wrong. The axles I got out of the 86 are very much 3.54s.
That's not ideal since I want to go to 31s when all the bodywork is done. I'm torn between what to do, but I think for now it will just get both 3.54 axles and I'll keep my eye out for an xj at the scrap yard. If I end up regearing anything, then I'm just going to go 4.88 and run 33s.
Anyway, I'm punching this in while I'm waiting for the front axle to dry after a good pressure wash.
The trans and tcase are out.
I got a new transmission mount, too cheap to not just replace even though it looks decent.
New front fenders are here. Again, too cheap to not justify.
Got some new window seals. Boy are those overpriced.
Won an 80s Alpine cassette deck off ebay, so I'm in the market for some tapes. Speakers are missing, and I don't know if there's even wiring to the doors, so that's something to do.
It came with a few interior door panels of different style. Now it's got the same on both sides, I read that they may be off a laredo? Got a set of arm rests here too but they're grey, so I need to paint/dye them either tan to match or black. Any advice for that would be awesome.
Share this post
Link to post
yeah, 1986 was a weird year in which they hadn't yet standardized the ratios yet.  bummer man :(
looks like a great project regardless :L:
Share this post
Link to post
Score! Somebody saw my truck in town and left a note yesterday.
Today I got to open a brand new Mopar bumper from 1993 for $50
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
