Renix cruise with an ax15?
The trans doesn’t matter. The question is whether your truck had cruise control originally. If not you will need to find all the parts. Search junk yards for an 87-90 XJ with CC. Be sure to grab EVERYTHING CC related
What is "everything"? That is the question. I have the vacuum canister (4 line), column, cruise motor, full cluster, short cable off it, yellow box. I don't know if that's all of it. The last time I had a renix with cruise was 12 or 13 years ago and it was my very first jeep and knew very little.
I got the brake light switch, but the clutch switch I do not have thank you. That slipped my mind. I'm guessing it has a funky clip setup like the brake and will need to source one. I know there is different pedal assembles. I believe I have a 91 and 92 h.o. clutch pedal assemblies and switch perhaps. Thanks for the help.
