I’ve gotte. Lots done just haven’t been posting about it.
Welded the truss on the front Dana 50. Patched the holes in the floor and layed down some sound deading. I have the fenders and clip pulled and am in the process of getting a 00’ fenders and clip.
Share this post
Link to post
I used thin sticky back aluminum to lay down on the firewall and tunnel. Used the leftover to cover the back of the cab. I am more worried about heat then sound deading since I’m planning on removing the doors
Share this post
Link to post
Before I put the interior back together I swapped out the headlight switch and gotta get a center console since I’m switching to bucket seats.
Share this post
Link to post
2 hours ago, dustyinthedirt said:
Thanks. I feel like I do a lot and am getting not very far
I know the feeling very well. Keep at it and, all the sudden it’s nearly done....
Share this post
Link to post
I’ve been tieing up loose ends in the cab. I altered a centerconsole to fit. There was only two xjs with tan interior in the pickapart. They did have three Comanches in there that I scavenged pretty hard. I may or may not have three sets of taillights... also got a passenger side window regulator (which somebody had already replaced in that vehicle so I got some hardware with it instead of drilling out rivets) and a climate control.
I had to peice the console together to make it work. I got the console and back bracket from one the black trim bezel from another, and the latch from another. I had to fix the console with some JB Plasticweld, since it was broken. Also who knew wood working tools would cut plastic trim perfectly
Share this post
Link to post
Layed the vinyl in this morning only took 7.5 hours to do it and get the interior panels back in. It fits “okay”. I purchased this vinyl flooring almost a year ago and it’s sat unfolded and flat for that long in a spare room. Using a heat gun made it easier to manover around. I wish it would have been warm enough to leave it out side in the sun for a few hours. I will try to get the rest of the wrinkles out during final install. Now to alter the seat brackets
Share this post
Link to post
After getting the vinyl layed and the trim in. I started on the seat brackets. I should have done this before I put the trim in. Here is a little sample of what we have going on. I’m gonna do a write up on this seat bracket alteration. It was way simpler then expected73548D2F-FB7D-4F4D-A978-736B478FEFD3.jpeg.2e6ca9c0578b96295d7f1d72f7f13e54.jpeg
Share this post
Link to post
Interior is in. I haven’t mounted the console officially yet. I’m not super happy with the fitment.
The seats slide really nice. They sit about 1.75-2” higher. I have way more leg room. The interior feels much more roomy.
The gauge cluster lights did not work at all so I wanted to tackle that. I did the ground relocation and only had half of them :doh: after making a post and “ohms” replayed and really helped me trouble shooting it and gave me a sweet link to a electrical diagram for the truck. I really appreciate it man!!
The lights where not working because of the foil on the back of the instrument gauges was slightly  tarnished. A little scotch brite fixed it.
Share this post
Link to post
Terrible pic but the axle sorta in position. Needs to be forward a bit more. The sterling measures 12” (no brake rotors) from the outside of the leaf to the face of the hub where the wheel would seat. I believe the stock d30 is only eight and a 1/4.. but I measured from the pad where the leaf would sit to the face of the drum. Since they where already off.
Share this post
Link to post
Clayton off road 3link crossmember is pretty nice. I’m gonna stitch it to the frame since there are only two bolts holding it and it is gonna have some serious stress on it. I can remove the middle section to drop the transmission. It is about a 1/2 inch lower.
Share this post
Link to post
The mounts for the links on the crossmember come out Straight with the body. I need them to be a little angled to match the axle side of the links. Since the axle is almost 10” wider the control arms are pretty wide on the axle. The crossmember is around 28” center of link to center of link and the axle side is close to 43” center of link  to center of link.
I was able to get the rear sitting on its own weight on the sterling 10.5, pinion angle set and for big racks on each of the u bolt eliminators. We only had to jack the truck up and set down 8 times before we knew it was straight. :crossfingers:01D13B9C-479A-4399-ABFA-9BF21F9A0FAD.jpeg.ec99a4d154fa3c02378a820dab5c2a79.jpeg
I have a string run down the side of the truck off the back wheels trying to square the front with the rear.
Share this post
Link to post
The links/mounts and coil buckets have all been tacked into place. I’m using a Johnny joint on the body side and a Heim on the axle. The axle sits about a inch to far forward and there isn’t much adjustment left on the joints. I’ve got to cut the tacks loose from the links pull the inserts out, cut a inch off and reweld. :brickwall: the springs sit about two inches further out left to right then stock so they have a litttle lean in them
Share this post
Link to post
Made up a diagram to show how the pinion moves through articulation. I couldn’t wrap my head around it otherwise
Share this post
Link to post
It is really coming together nicely man! I want to see it moving under its own power
Share this post
Link to post
Thank you! I can’t wait to see it move. I’m hoping by the end of the week I’ll be able to order driveshafts
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
