Jacob Ochs
1986 2.8L to Turbo 3.4L to 4.0L MJ....
I also forgot to add that I bought #50 Bosch Injectors! That was a big part.
Here's more pictures of my MJ it's going in. 99988f8f5bcc3bf2e619721d93e31051.jpgc078d842a12896c2a790162d6ccb7f1b.jpga65b9fdd60d279c974c2b97e8a087f11.jpg87f4ec73d8ee8b4bc84ef9c88c8b2e40.jpg5daaceae21d813543fec9da64159a832.jpg
Share this post
Link to post
I think 300 hp will keep a smile on your face :D  no need to test the limits of your engine unless it's for competition like the camaro guys.  you're definitely going to want that AX-15 conversion. the AX-5 won't last long behind that power level. :(
Share this post
Link to post
That engine will make WAY more than that with ease. What boost are you planning on? id put a 10 lb spring in the wastegate and tune there. See what you get.
 t3/t4 junk turbo we had laying around, on a buddies junker B20 honda motor. STOCK everything, on pump gas. Totally safe tune... 12 psi it made 300/300 at the tire. thats a 2 liter. lol
 So yeah you will have quite a bit of power id guess. That turbo isnt in its efficiency range till about 15 psi. So you will barely be using it.
 You have a good tuner nearby?  tune is everything.
Hope it turns out great. Need a tuner LMK.   Dave
Share this post
Link to post
I might just have to hold you to that! I don't have anyone that I personally know just a few performance shops I've heard great things from!
Share this post
Link to post
Anything above the measly 115hp of the 2.8 will keep me satisfied! Yes for sure, the AX- 5 will leave in time but I'm assuming that time will come soon! I'm not sure how the clutch will hold to the power increase from the new motor! I'm not sure how the T5 transmission compares to the AX- 5 but if they're anywhere near the same the AX- 5 will be slipping!
Share this post
Link to post
Thanks for your service! I will be intently watching this project...God bless ya.
Thank you for your support! I will be getting a good hold of the project April, I'm in the process of finding a 2wd MJ as a daily driver while this project will be taken on!
Share this post
Link to post
I like were this is going ! As for the clutch I'm running the center force stage 2 clutch behind my 3.4 / AX-5 and love it ! I don't have 300hp but for the beating I give it off-road and the noticeable difference from the stock it's well worth the money
Share this post
Link to post
I'd like to see this intercooler mounted. I'm looking for one but can't find one the right size.
It will be a little bit but I'll post pictures when it's mocked up
Share this post
Link to post
The dude on the left. Is his name Jack?
Share this post
Link to post
No, his name is Jonathan!
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
