On 9/1/2018 at 9:07 PM, Longview said:
YJ external slave bellhousing?
Read the thread, super cool jeep.
Sent from my SM-N920V using Tapatalk
I think you mean YJ transmission with an external slave bell housing?
Otherwise it sticks out under the truck like a soar thumb under the frame to all the rocks
Share this post
Link to post
Thats what i was thinking, but your first post listed a "external slave bell housing from a 1990 YJ", which doesnt exsist.
Share this post
Link to post
you made me check, even did a search query
all could find was
Quote
External Slave AX-15 from 1990 YJ to achieve a flatbelly via transfer case clock angle
so i am confused on what your talking about, i think that explains itself? thanks for reading my build thread though! i guess i should of  put a comma after external slave to make it easier to understand :D
Share this post
Link to post
Not important LOL.
But what i was trying to say is there is no such thing as an external slave AX15 from a Yj of any year.
Share this post
Link to post
since my last update a few things have happened.
the last trip to apex, we stopped in the nearest town to get some food.
while hanging out in the parking lot i noticed my rear diff housing had failed. (the right tube has always been bent since i owned the truck, i guess i gave it the final nudge haha)
so called the tow truck and get er hauled back home.
1ce7d213-36ed-40eb-b2ec-1a8f5a729ee6-ori
5e0c5545-cbdd-4958-9116-dd24f8721211-ori
40711849-61e9-437b-9622-9158d78cb84d-ori
i ended up picking up another scout II d44 housing for $40, it needed alot of cleaning before i even was able to put the gearset in.
but i shimmed it all into place. and meticulously cleaned the entire housing
c0ac2f8b-b1bf-45e0-9f35-e8c337d95ccb-ori
edf6447e-3581-426f-b856-013be9994aea-ori
16961142-fdea-48d8-8e66-fee317bb06ff-ori
5ddf386f-5dc7-44ec-99c8-3b52582a3368-ori
d3557061-378f-4514-bb41-dc57d981949e-ori
Share this post
Link to post
I then cut the retainers off my axle shafts, since my disc brake conversion brackets become the new retainers
and with the help of my friend designed and made a truss for the new axle
9f7a8725-5d9b-4336-9679-84f41069a0fb-ori
be4bedaf-f03a-4c39-b1fa-e98ccd8fbf0e-ori
83dfc091-f6c9-4f92-b42a-a553f43966a6-ori
23ec783c-5ad8-4d06-ba51-8012c56243bd-ori
fd5377b3-7e39-49bf-a3e1-7ba8d243c505-ori
Share this post
Link to post
i then painted the axle, once it was stitched together.  everything else had a thorough final clean, then  mostly every part got a fresh coat of paint.
tossed the axle back under the truck and back out into the bush
there is a few reasons why i stayed with the dana 44 under the truck instead of going to a 1 ton axle
unsprung weight, would to too great and i would have to stiffen the truck (i will down the road  but not now) before i could even think about driving it again
new rims and tires
all new gears locker upgraded shafts ect... for me currently that financially isnt an option
the biggest one though is diff clearance.
the way the truck is set up is to achieve maximum diff clearance ,the axles are strong enough built up to withstand the 39.5 tires
snow wheeling is HUGE here, and it is my favorite season. diff clearance is critical. if i went to a 14 bolt and shaved the lower portion of the housing i still would loose clearance and that is not an option.
that being said, i also maintain a large sidewall keeping the 15" rims
659ff610-7242-4149-a1ce-c7b0852a903d-ori
4bf1dfd2-0bd7-4860-9d94-1c776c9ad24e-ori
7ad791a5-1019-47d6-843a-70749e186121-ori
f450876d-ae5f-409f-a676-6f03b5c6efa2-ori
2145c53c-2f83-4905-bc9b-61c550b7a746-ori
aae9603b-faf8-4c6b-9114-cb3a01ee448d-ori
Share this post
Link to post
i ended up finding play in my upper ball joint bore of the knuckle (the ball joint did not have play)
so i sourced out a new scout II knuckle for $20, tossed some new ball joints in it and reamed it for a over knuckle 1 ton TRE
i had to cut off the old knuckle, since it was no good, i had zero issue chopping it up.
otherwise i would have taken a sawzall and cut the upper and lower balljoints out
with the RCV's in a Scout II spicer 44 (dana 44) they have to be installed assembled at the same time as the knuckle is being installed ( it is a bit of a royal pain)
in order to disassemble the axle, you literally have to cut the knuckles off. it is a one way installation. once they are installed. there is no nice way of removal
at this time, i refreshed 1 ton over knuckle steering with all new TRE's and put it all back together
20962234-7b23-40d9-98dc-eecf05a341fa-ori
dc4976c8-5541-48ef-a06a-9f66b98af624-ori
7ea14508-2265-4ae0-ba0d-7ee9922ed547-ori
08508a91-64d8-4a26-9a90-771f6f444ec5-ori
687f79cf-9f70-4934-a942-73d891efa403-ori
b1326799-9271-4df9-bef0-68f2bda1c901-ori
also just some randoms. i refreshed my comanche badges, cleaned, polished, repainted the black and a generous amount of clear coat
and side by side my buddy's 2" lowered cherokee, that walks most of the imports in town
and me testing out the new parts
520103f2-a8e3-4cc9-a824-df38d5a84ee1-ori
32c9c9e7-b565-492d-bb64-f8bec2dd9f9e-ori
c9c263b9-9861-4434-89d0-a4999219dcce-ori
Share this post
Link to post
