Conn Posted January 15, 2006 Share Posted January 15, 2006 I've currently got the BA10 puke box. It shifts good, but i'm a little gun shy of it. I don't like the idea of the computer controlled AW4, although I hear it's a very reliable transmission, and readily available for cheap. Has anyone swapped in a 999 trans from say a 91-95 4.0 Wrangler? I'm h*ll bent on having an automatic in this rig, but may have no other option than the AX-15 if i keep being as picky as I have been. Is swapping in an AW4 going to be more of a pain than a non computer controlled 999? I'm not sure how much wiring actually goes along with the AW4s. thanks for any help. Link to comment Share on other sites More sharing options...
whowey Posted January 15, 2006 Share Posted January 15, 2006 'Computer controlled' is kinda a misnomer for the AW-4. It consists of one TCU, and one plug. The TCU is self contained, and its not really a big deal. The TPS on the motor is different also. A puke-goat uses a three pin, and a AW-4 uses a 4 pin. On both of my 88's the plug for the other TPS is there. Link to comment Share on other sites More sharing options...
Pete M Posted January 15, 2006 Share Posted January 15, 2006 The 999 doesn't have overdrive. Jeep on! --Pete Link to comment Share on other sites More sharing options...
87manche Posted January 16, 2006 Share Posted January 16, 2006 http://awshifting.com/ manumatic Link to comment Share on other sites More sharing options...
Bounty Hunter Posted January 17, 2006 Share Posted January 17, 2006 A big seller for many Wrangler owners converting over to the AW4 is the benefit of the overdrive, allows you to keep the axles geared lower while maintaining driveability. If you're worried about the TCU, wire it up to shift manually with a switch, controlling torque converter lockup manually as well. Link to comment Share on other sites More sharing options...
