Busted Exh. Manifold Flange.
I know the not so easy but straight forward method of fixing this is to buy a new mainfold, but the canadian verson of uncle sam doesn't pay me enough to do so.
I busted my exhuast pipe off right at the flange, the top piece of the flange (manifold side) came right off. I was thinking...
Can I just ram an exhaust pipe expander on the "good" pipe after cutting off the flange and clamp that bad boy off? Does anybody know if the sizes are the same.
Exhaust is not my speciality.
If you have to push the exhaust pipe up an inch or so to get it over the exhaust manifold and clamp it it may not work since it crosses over to the other side of the engine and I don't think there is that much room above where it crosses over. Seems like the oxygen sensor is close to the end of the manifold too so you won't have much to room there either. You'll never know until you try it and if it doesn't work you'll be buying an exhast manifold and the exhaust pipe. I would take it to a muffler shop and see if they can weld the flange back on.
Mac...
