DJM/78 Posted December 21, 2009 Share Posted December 21, 2009 So this weekend , I was washing my door panels wile servicing my door hinges and made a big mistake. I had pulled some parts for paint and was using a paint prep spray, when I grabbed the wrong can sitting right next to the prep spray , clearly marked , " Gum out , carb & choke cleaner " , and sprayed the bottom of the door panel . Instantly realizing my mistake , I felled profanities whilst franticly looking for my rags . when I wiped the surface , I noticed a bleach - spot where the chemical stayed on the surface . However staining the surface. I decided to do the whole door panel to match. Wiped it all clean and then soaked them in Formula 2001 protectant. Took about 15 years of oil , grease and paint off . As bad as it sounds , It looks great !!! Before : After: Link to comment Share on other sites More sharing options...
Red 1989 MJ Posted December 21, 2009 Share Posted December 21, 2009 Look great!! ;) Do you have a photo of the can ? Link to comment Share on other sites More sharing options...
DJM/78 Posted December 21, 2009 Author Share Posted December 21, 2009 I don't , but the product brand was Gum-out , Carb & Choke cleaner . White can , red label , just like my prep spray . I believe GUM-OUT products are sold in all auto parts stores everywhere . I bet there are other carb. cleaners with the same chemicals. Spray it on and curse profanities , let sit for about , 5-10 sec. , and wipe clean . Repeat until desired blend of color match . Soak in w/ some kind of vinyl or plastic protectant . This only worked on my grey interior . I don't have the balls to try on anything else . :fool: Dave M. Link to comment Share on other sites More sharing options...
freakjeep93 Posted December 21, 2009 Share Posted December 21, 2009 lol perfect way to butify youi interior Link to comment Share on other sites More sharing options...
WBKrazy Posted December 21, 2009 Share Posted December 21, 2009 haha.. looks good! brake cleaner will do the same thing, usually ill soak a rag with it and wipe down whatever i want to clean Link to comment Share on other sites More sharing options...
whowey Posted December 21, 2009 Share Posted December 21, 2009 Came out very good looking.... But be VERY careful with gumout carb cleaner... It will peel the paint off of things.. especially ones you don't want the paint peeled off of. Link to comment Share on other sites More sharing options...
DJM/78 Posted December 21, 2009 Author Share Posted December 21, 2009 Oh ' yeah" , :agree: Not only did it take paint and stain off , It instantly liquified the factory coating on the panels . leaving an almost brand new surface , or better in my opinion . However you can't let it soak , wipe after 5- 10 seconds . It bleached the surface about two shades brighter . I know that stuffs nasty , be quick to wipe it up . :shake: Link to comment Share on other sites More sharing options...
88mjmanche Posted December 22, 2009 Share Posted December 22, 2009 holy crap thats fing sweet I'm gona do that :bowdown: Link to comment Share on other sites More sharing options...
comanchedude Posted December 25, 2009 Share Posted December 25, 2009 Westlys bleach white for tires does great at this also, have used it for years to clean leather and vinyl upholstery.. as well as to remove window tint film glue.. and of course tires Link to comment Share on other sites More sharing options...
streetjeep2.5 Posted December 25, 2009 Share Posted December 25, 2009 Been using DuraGloss Vinyl and Leather Dressing. Does a good job! Smells nice! Use it on my Tonneau also. Link to comment Share on other sites More sharing options...
avnsteve Posted December 25, 2009 Share Posted December 25, 2009 and curse profanities , Dave M. is this a really critical step in the process? I'm just trying to be sure i do it right... :yes: Link to comment Share on other sites More sharing options...
DJM/78 Posted December 26, 2009 Author Share Posted December 26, 2009 :rotfl2: Yeah , I'm just going step by step on what worked for me . I think the cursing , helps speed up the process . Brake cleaner works the same . Almost the same chemicals . smells Identical . Keep in mind , my door panels had stain and paint all over the door . Looked like willy didn't make it to the outhouse . :ack: Dave M. Link to comment Share on other sites More sharing options...
