I might have new information on the subject. Initially, I follow the trend and removed the bench seat brackets and mounted them under Cherokee seats. Sure enough the seats are high and inboard. I have a Cherokee so my goal is to locate the buckets as they are in the Cherokee. I decided to use the Cherokee brackets and modify as required. I decided that the inboard studs are in the same location as the Cherokee but at different heights. I drilled a new hole in the front bracket for the ou
