Fender Flare Kit and the Fender Flare Retainer Kit by Crown®
Comanche rear flares are NOT the same as 2-door Cherokee rear flares. The Comanche wheel arch is longer and higher.
Cherokee rear flares WILL NOT fit a Comanche. This thread is not about aftermarket flares, it's about OEM replacements. OEM Cherokee flares are one piece, regardless of whether it's a 2-door or a 4-door.
I don't know who started this rumor, but it just will not die... 2 DOOR CHEROKEE REAR FLARES DO NOT FIT ON A COMANCHE!
The Crown kit will work fine for the front. I'm running the Crown stock replacement retainers on my 91 and I have no complaints. It's pretty much an exact reproduction of the factory part.
Thank You Guys. I got two sets of older Flares but the Jeep is being painted so I was interested in New. I bought the Retainer kit, I may be able to adapt the back retainers. The Comanche is a 1988 4 Cyl 2WD Standard. Most of my fixes came off of a 1986 Comanche 4WD with V6 that developed blow-by and was carburetor so it's in my Yard.
