AX15 swap, t case vacuum line questions
I've got two np231 cases (91 & 92) , both have the port in the front like you're new one (as do the 88 np231 & 85 np207 I have) . thought the back port for the switch was later years.
I think you can just swap the vacuum switch to that position you ought to have enough vacuum harness since it was connecting to the back of the case.
If you don't have a vacuum disconnect axel you could eliminate the vacuum part of it if you want.
Sent from my iPhone using Tapatalk Pro
