External Slave AX15 swap, lets see how it goes
Welp, the BA10 bit the dust. I'm going to try to cover most of the swap. There are other write ups out there that I'm sure would do a better job of covering this but I'm going to try to show everything from my "fairly inexperienced" position. I hope this will be just what someone is looking for to help them get their swap done. A swap is my only option as I AM NOT replacing the poo goat tranny. Since this is my first write up, it's a learning curve. I'm going to try to break it up into sections.
You picked a fine time to leave me first gear. Driving to school on 1-13-17, I let the clutch out in first, got going and three clunks and a thud later I added myself a second neutral position. So I pulled over, gave it the seventeen second inspection, crossed the toes and kept driving. It sounds like a box of rocks getting beat around by a 200 pound gorilla but it still drives. 140 miles later it's still driving but just how long is unknown. (Picture of crippled jeep added for artistic flare)
Sourcing a donor. I'm either going to go with an AX15 or a NV3550, whichever pops up first is what I'm going with.The odds of an NV3550 showing up in the middle of NoDak is slim, so AX15 it will be. I am requiring myself to avoid internal slave as I am trying to avoid issues, not cause more. I'm trying to source a complete parts jeep for $400 or less as to keep my total swap budget under $750. I will update when a donor is found, and go from there.
That's not a junkyard item up there? I'm going to try to reuse the one on a donor vehicle,once I find one
Sent from my XT1635-02 using Tapatalk
Yeah its a junkyard item, but 1994+ manual Jeeps seem to be harder to come by these days. Had to do a 6 hour round trip to get my transmission...
Sent from my SM-N900W8 using Tapatalk
  • 3 weeks later...
Going to pull the motor and trans from the donor jeep today, I've spent the last four days carefully unhook stuff as to save the harness for a future swap possibly? FedEx should get the parts to me by Monday or Tuesday and I will update with a step by step guide and lots of pictures on the actually conversion.
OK HERE IT GOES GUYS AND GALS! Here's the parts list
Dorman pilot bushing, number is stamped on it2c15bcbabce9ec7d9769a8a5da5a05ab.jpg
Flywheel for your year Jeep
Clutch for the year of transmission
Boot since mine was destroyed.
So you're going to want ago ahead and undo your rear driveshaft strap bolts, there's for of them then slide the rear driveshaft off. Make sure you drain the transfer case first
Undo the transfer case skid if equipped then remove the 6 cross member bolts leaving the two studs in
Remove the four strap bolts on the front axles and four bolts on the t case front yoke and then remove the front driveshaft
Undo the speedometer, vacuum switch and reverse light wires
Undo your exhaust, I don't have pictures since I'm cutting mine off and redoing it all.
Remove the two starter and one bellhousing bolt near the starter
Remove the four transmission mount bolts
Undo the transfer case linkage from the t case and body
Lower the assembly with a jack and get a long extension and under the top engine star bolts
Remove the four lower bellhousing bolts. I'll call this a wrap for day one 42f84ef7985fc68c96fdcf9315ea0dcd.jpg
I just received my Dorman pilot bushing today to do my swap, same part number on the box, but not stamped on the bushing itself. Got them from amazon, they sent me a box of 5 for some reason. Look forward to seeing your progress, I have to do this in the next couple weeks.
You're going to need to cut down to 3/4. Part number 690-042 is 7/8" long and will not fit in the renix crank! I'll update pictures tonight of today's and yesterday's progress
Same here. Soon as my motor rebuild is done I'm going to start looking at my AX15. No one here will rebuild them so going to be grabbing a fresh one off eBay most likely. Would like to convert it to external slave but clueless. Ive dropped an AW4 before but never messed with the AX15's.
Really? I was under the impression it was a straight swap! What did you use to cut them? A grinder? Probably a good thing I have 5 of them now, I got 5 chances to get it right!
You can put it in as is but it is too long, not sure if being too long would affect it or not. Tonight or tomorrow I'll finish the write up.
