FUEL PUMPS
when I reinstall my fuel tank with pump back in my 88 Eliminator which had the stock 4.0 but now has 96 4.0 that's now a 4.7 stroker.
will the original fuel pump be able to feed the stroker? I do still have the tank and pump from my 96 ZJ where the 4.7 started its life as a 4.0 came from.
Maybe fine, maybe not depending on the injectors and fuel rail you are using. The 96 and up engines use injectors that run 10psi higher than the earlier ones (31-39psi vs. 41-49psi), so you will need to swap to a later fixed fuel pressure regulator or go with an adjustable FPR from Hesco or similar.
Doing some research I'm thinking on going to these Injectors ( Accell 150826 Fuel Injectors, 26 lbs./hr., 14.4 Ohms Impedance, 12 V,)
Than building my header from a Clifford header I had on a 300 inline ford 6cyl the stroker should be able to inhale and exhale without any restrictions
