What are these plugs for?
You can add a w/s reservoir from the equivalent XJ application that has the level sensor to your MJ and plug in it.  Add a bulb to the appropriate socket in the indicator panel to the left of the instruments, and you are good to go!
I stuck in the 97+ washer tank inside the left fender well, and the washer fluid level indicator definitely comes in handy. The bulb was already there on the cluster.
