81Chero Posted January 19, 2016 Share Posted January 19, 2016 Someone posted that WIX 51515 is an added capacity filter than the standard 4.0L filter. Also, NAPA dose have a Platinum line for Synthetic oils. Oversize Oil Filters (3/4"x16 thread) 5.178" HIGH, 3.660" DIAMETER AC-Delco PF2 Motorcraft FL-1A Purolator L30001 Napa 1515 Wix 51515 Mopar L-72 L-326, L-526, L-55, L-1007, L-138 Baldwin B118 Hastings LF115 Mobil 1 M1-301 Amsoil EaO15 Donaldson P550008 6.93" HIGH, 3.660" DIAMETER AC-Delco PF42 Motorcraft FL299 Purolator L40017 Napa 1773 Wix 51773 Mopar L-526 Thanks again Hornbrod. That's good info. (should be in the DIY section) I've used Amsoil for over 20yrs in most everything. If I get a high mileage vehicle, I over fill it some with Rotella 15w40 and some seafoam or marvel just to see what's going on with temp or leaks and then after flushing a few times, i switch to amsoil and EA filter 10w30 or 0w20 since It doesn't get that cold here. then change it once or twice a year and filters inbetween. NEVER had an issue. Errol Link to comment Share on other sites More sharing options...
mvusse Posted January 30, 2016 Share Posted January 30, 2016 Mobil 1 high mileage 10W30 for synthetic or Quaker State Defy 10W30 for conventional. Both are still API SL and thus still have ZDDP in it. 4 stroke motorcycle oils are all rated API SJ because they need large amounts of ZDDP. Link to comment Share on other sites More sharing options...
Megadan Posted January 30, 2016 Share Posted January 30, 2016 Rotella T6 synthetic 10W40 and a Wix or Bosch Filter. Link to comment Share on other sites More sharing options...
tugalo Posted January 31, 2016 Share Posted January 31, 2016 Good info on the Delo diesel oil. i've been running Rotella T6 but based on the zinc content, i think i will switch. Link to comment Share on other sites More sharing options...
Tanner Posted January 31, 2016 Share Posted January 31, 2016 I use royal purple 10w30 year round after my rebuild. Link to comment Share on other sites More sharing options...
Crash Posted February 1, 2016 Share Posted February 1, 2016 Good info on the Delo diesel oil. i've been running Rotella T6 but based on the zinc content, i think i will switch. Valvoline VR1 Racing oil has zddp in it.. There are also additives that you can buy as well. Link to comment Share on other sites More sharing options...
HOrnbrod Posted February 1, 2016 Share Posted February 1, 2016 Good info on the Delo diesel oil. i've been running Rotella T6 but based on the zinc content, i think i will switch. Valvoline VR1 Racing oil has zddp in it.. There are also additives that you can buy as well. Really? Link to comment Share on other sites More sharing options...
Incommando Posted February 1, 2016 Share Posted February 1, 2016 Rotella and Napa Gold/Wix go together like peas and carrots.......... This. I use 15w40 in my 225,000 engine. Link to comment Share on other sites More sharing options...
Crash Posted February 2, 2016 Share Posted February 2, 2016 Good info on the Delo diesel oil. i've been running Rotella T6 but based on the zinc content, i think i will switch. Valvoline VR1 Racing oil has zddp in it.. There are also additives that you can buy as well. Really? Not sure if there was sarcasm, or if you were serious. But it says it on the bottle.. Since I work at a Ford dealer currently, I think I will use some Motorcrap.. I mean, craft oil since I get it for a reasonable price. Been tempted to use some of the 10W30 Super Duty diesel oil. But might stick with the 15W40. Link to comment Share on other sites More sharing options...
big66440 Posted February 3, 2016 Author Share Posted February 3, 2016 More importantly, which oil filters are you using? There's some real junk out there that can cause damage to our beloved 4.0s with the upside down mounting of the filter. I run either K&N, Parts Master ( Wix ) or Napa Gold. Link to comment Share on other sites More sharing options...
xjrev10 Posted February 5, 2016 Share Posted February 5, 2016 Rotella and WIX......echoooooooo...... Ha Link to comment Share on other sites More sharing options...
