Ax-5 master with ax-15
So my truck currently has an ax-5 trans. When i get around swap in my ax-15 can i keep the ax5 master cylinder or will i need to find one fo an ax-15 also the ax-5 has an external slave and the ax-15 has an internal one.
Thank you
How are you going to put an AX-15 on a 2.8L engine? The bell housing is different, and the input shaft diameter is different so you'll need a different clutch.
I'm just compiling info right now, but like 88whitemance said I have also been on the lookout for a second gen dakotas, because if a find one I might be tempted to swap the trans sooner rather than later.
