mikekaz1 Posted July 29, 2015 Share Posted July 29, 2015 so my MJ doesn't have factory air but my parts truck does. its set up for r12 as its an '88. now I know I can get the o ring retro kit for r134. BUT my main question is has anyone tried the "NEW" legal R12A refrigerant? its suppose to be a direct swap with r12. and have similar COLDER properties to r12 than r134. Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 29, 2015 Share Posted July 29, 2015 I haven't tried it yet, but might the next time I need to recharge since my R12 stash is gone now. Link to comment Share on other sites More sharing options...
Megadan Posted July 29, 2015 Share Posted July 29, 2015 R12A is just a propane based hydrocarbon refrigerant (which means flammable). If you search you will see people who either love it or hate it. From what I know, it operates at lower pressures from R12, so following charge instructions for said refrigerant would be key to optimum operational efficiency. Link to comment Share on other sites More sharing options...
mikekaz1 Posted July 29, 2015 Author Share Posted July 29, 2015 I was looking it up, doesn't sound like a half bad alternative, at a lower cost then a retrofit also. and to branch off the flammable part, I think I read something about a 1300 degree flashpoint which I would think to be about double any expected temps anyways Link to comment Share on other sites More sharing options...
mikekaz1 Posted July 29, 2015 Author Share Posted July 29, 2015 http://www.amazon.com/RED-TEK-R12a-Refrigerant-Recharge/dp/B00DJDYORU $70 not bad Link to comment Share on other sites More sharing options...
DaveJ33P Posted July 29, 2015 Share Posted July 29, 2015 I'm experimenting with R152a in my '99 Cherokee. I got the idea from here: http://www.rx7club.com/2nd-generation-specific-1986-1992-17/c-charging-easy-cheap-safe-alternative-refrigerant-964688/ I discovered my compressor is bad, so I don't have a definitive apprasial yet. Link to comment Share on other sites More sharing options...
zomeizter Posted July 30, 2015 Share Posted July 30, 2015 Interesting stuff here, too bad I just completed my retro to 134a, update us with how that stuff works out... Link to comment Share on other sites More sharing options...
Katzer Posted July 31, 2015 Share Posted July 31, 2015 I just used enviro-safes r-12,134a substitute. It is cools well. Doesnt turn it into an icebox but it works. I would use it again. Link to comment Share on other sites More sharing options...
zomeizter Posted August 1, 2015 Share Posted August 1, 2015 Funny you say that, I guess my conversion went very well because my cab does become an "ice box". I have to keep the blower fan on low, even in stop and go traffic in town. All new parts and flushing make a big difference... Link to comment Share on other sites More sharing options...
mikekaz1 Posted August 2, 2015 Author Share Posted August 2, 2015 I'm doing a full parts install as mine isn't AC optioned. So on that note are the electronics also plug and play? Or should I just use a toggle switch? Link to comment Share on other sites More sharing options...
Katzer Posted August 3, 2015 Share Posted August 3, 2015 It won't be plug and play because the control on your dash doesn't have AC on it. You will have to source a unit from the scrap yard. Link to comment Share on other sites More sharing options...
mikekaz1 Posted August 4, 2015 Author Share Posted August 4, 2015 well i know that obviously, i guess my real question would be are the fuse/relay connections factory wired to work with the addition of the dash controls and equipment? or is there still intermediate control wires/connections missing Link to comment Share on other sites More sharing options...
